Dimmer switch not dimming properly
6 posts   •   Page 1 of 1
diygaz
by diygaz » Thu Jul 17, 2008 2:42 pm
Few months ago installed a brand new dimmer switch which worked perfectly up until recently
The dimmer would dim the light variably as it is supposed to do until recently, if the dimmer switch is on full then the light will be on full brightness but as soon as you turn the dimmer down the faintest of touches the light starts to flicker then will go off as apposed to dimming down.
Has anybody any ideas what the problem could be.
The dimmer switch is rated as 400w max and i am just using an ordinary bayonet fitting lightbulb 60w rating
BLAKEY1963
Re: Dimmer switch not dimming properly
by BLAKEY1963 » Fri Jul 18, 2008 12:03 am
[quote="diygaz"]Few months ago installed a brand new dimmer switch which worked perfectly up until recently
The dimmer switch is rated as 400w max and i am just using an ordinary bayonet fitting lightbulb 60w rating[/quote]
DIYGAZ
Take the dimmer back and explain the problem.
BLAKEY1963
diygaz
by diygaz » Fri Jul 18, 2008 6:12 am
Thats a bit hard as the item was purchased on Ebay
Kev.L
by Kev.L » Fri Jul 18, 2008 5:54 pm
Throw the switch away and buy a new one!
by ericmark » Mon Jul 21, 2008 10:58 am
Sorry to say most likely the dimmer has blown but before you give up try a different make of light bulb. Light bulbs have a coiled coil element so there is some inductance and some capacitance and some times it reacts with the dimmer causing odd effects. It is rare with modern dimmers but worth a try.
All best Eric
by sparx » Mon Jul 21, 2008 5:34 pm
Hi dimmer for 400 watts will have a minimum rating as well which may be more than 60Watts, try 100watt lamp to prove it
regards SPARX
It is currently Tue Dec 03, 2024 3:44 pm
