Shelves on plasterboard walls
ewanandmarjy
by ewanandmarjy » Mon Aug 04, 2008 10:16 am
Two kitchen shelves came crashing down yesterday, and I need to get them back up (safely) before the mother-in-law arrives.
Help!
The plasterboard is about 2cm thick and there is a cavity which 9cm to the other wall, which is the living room and is also plasterboard
The shelves fell down as the screws fell out of the holes, the plasterboard seems a little damaged around the holes on a couple of them
so how should I best put the bracket fixings, back onto the walls?
I've been looking at hollow wall anchors, will these do the job?
thanks for your help
Ewan
TheDoctor4
by TheDoctor4 » Mon Aug 04, 2008 4:11 pm
Have you had a look at our DIY Projects section, especially the project on Plasterboard Fixings: https://www.diydoctor.org.uk/projects/fi ... rboard.htm
This may be able to assist you. If not, check out all our other projects.
Regards
It is currently Sun Dec 22, 2024 7:25 pm
