frost thermostats
allan.byrne
frost thermostats
by allan.byrne » Sun May 06, 2007 4:08 pm
Can someone tell me how a frost stat works nr to my boiler and do I really need it now my garage is now a room?
powerflushman
frost thermostats
by powerflushman » Mon May 21, 2007 8:49 pm
Hi The frost stat is there to protect the boiler, if the temp goes below a set temp about 5-7 degrees it will switch the boiler on so that it will protect it from frost damage. If it is not in the way I would leave it.
Hope this helps.
allan.byrne
by allan.byrne » Wed May 30, 2007 10:58 am
Hi thanks for replying, do you think it might be causing my pump/boiler to switch on/off itself when not timed to do so and is there a way to test it ? I
powerflushman
by powerflushman » Wed May 30, 2007 7:37 pm
Hi Yes that well could be it, try turning it down as low as it will go, and see if this stops the boiler coming on/off as often.
allan.byrne
frost thermostats
by allan.byrne » Sun Jun 03, 2007 9:53 am
Hi there, I turned the frost thermostat to minimum (it was at 5 degrees) and the problem with my self igniting boiler/pump has been ok up to now. many thanks
