Toilet syphon leaks
chriscrow
Toilet syphon leaks
by chriscrow » Sat Aug 16, 2008 10:06 am
Cistern leaking. I have changed the syphon in the toilet cysten and all works well. As soon as I add more water to check the overflow (which runs into pan) it starts dripping out at the bottom of the cistern. I cant see how or why this should happen as it works perfectly untill I test the overflow. I fitted a Dudley Turbo 88.
TheDoctor4
by TheDoctor4 » Sat Aug 16, 2008 11:05 am
Have you had a look at the DIY Doctor projects? There are several related to cisterns and leaks: https://www.diydoctor.org.uk/projects.htm
Regards
It is currently Mon Dec 02, 2024 11:01 pm
