replacing door
stronach
replacing door
by stronach » Wed Aug 20, 2008 4:41 pm
My back door needs replacing as it is rotting away, it is a softwood door. I would like to replace it with a hardwood door. Can it be fitted into the original frame if that is softwood? The frame is in good condition.
jaydott
replacing door
by jaydott » Wed Aug 27, 2008 8:04 pm
hi stronach
if you havent fitted the new door then yes you should b able to fit a hardwood door into the frame aslong as u buy the right size door ie 30 inch fram u would need to buy a 30inch door and shhot the door in but it should work any more questions wright back
It is currently Wed Nov 27, 2024 2:53 am
