best way to fill in large hole before papering
lizzie
by lizzie » Fri Aug 22, 2008 11:32 am
There is a hole left in the wall where a double electrical socket was. It's quite deep. What is the best way to fill it? (ihaven't a clue)
TheDoctor4
by TheDoctor4 » Fri Aug 22, 2008 6:18 pm
Have you had a look at the DIY projects area. There are several projects that deal with filling holes: https://www.diydoctor.org.uk/projects.htm
chris_on_tour2002
by chris_on_tour2002 » Sat Aug 30, 2008 9:34 am
i would get a small bag of bonding plaster. apply in two or three stages allowing each to harden (don't have to wait until it has completely dried, just until hard enough to apply another layer).
with the final application use a plasterer's trowel to make it flush with the wall. once set you can use either finishing plaster or even polyfilla and a light sanding to get a nice skimmed finish. not a difficult job at all, just make sure that however you do it that there are no live cables still lingering. wet plaster (or wet anything) and electrics don't mix.
It is currently Wed Nov 27, 2024 2:10 am
