soakaway problem
debobey
soakaway problem
by debobey » Sat Aug 23, 2008 4:38 pm
I am doing a soakaway and have dug it and the trench, now doing pipes. I was told to use soil stack pipe which I have ready but it has just dawned on me that when I put the rainwater pipe into the soil stack and fill in the trench, the soil will fal in the bigger opening of the soil stack. can I use all rainwater pipe. please help
Bob Plum
by Bob Plum » Sun Aug 31, 2008 2:32 pm
There will be a fitting available somewhere to join one to t'other but the usual trick is to overlap the pipes by a reasonable distance, one inside the other, loosely stuff newspaper between the two to about 2-3 inches from the top of the larger pipe, and then fill the gap with mortar. The newspaper eventually rots but has long since done its job.
It is currently Mon Nov 25, 2024 2:35 pm
