calibrating test equipment
ian2799
by ian2799 » Sun Aug 24, 2008 7:53 pm
hi guys just a quick one if you buy one of the calibrating boxes to check your meter do you then have to calibrate the check box
BLAKEY1963
Re: calibrating test equipment
by BLAKEY1963 » Tue Aug 26, 2008 2:30 am
[quote="ian2799"]hi guys just a quick one if you buy one of the calibrating boxes to check your meter do you then have to calibrate the check box[/quote]
IAN2799
When i brought my checkbox from the intrument calibator
who calibrates my intruments , on a yearly basis , there was
a manufacturers warrenty on the product for 10 months.
If your calibrator did not come with a manufactureres
warrenty , then u would need to get it it calibrated.
BLAKEY1963
by ericmark » Tue Aug 26, 2008 10:57 am
This did come up when I worked for GEC and I calibrated the stress relief equipment using a voltage source and it seems back in their main premises these were compared with a Daniel cell which gives out 1 volt. But when working for another firm having send away a PATester it returned from testing without the pass points which were required to enter on the computer program. When we inquired we had to return it as they had lost the traceable records to be re-tested at which point we were told it was an old design and could not be calibrated to the new 7Mohm pass limit only the old 1Mohm limit. This rather proved to me these so called calibration houses only pay lip service to the job of testing in the same way as the PATesting guy who walks around with a spool of labels and only gets tester out when someone is looking. And two premises with known socket readings is just as good I say two just in case the supply authority alter supply in some way.
Eric
It is currently Tue Jan 28, 2025 10:46 pm
