Light fitting sparked and blew fuse, now it doesnt work
ttony
by ttony » Thu Aug 28, 2008 1:12 pm
Hi, I turned the the light on in the kitchen and there was a pop and a spark.
This blew the fuse for the circuit it was on, so I changed the fuse and all the lights started working again but the one that blew doesnt.
Does the fitting have to be changed or is there a wiring fault or something?
Tone
TheDoctor4
by TheDoctor4 » Thu Aug 28, 2008 4:46 pm
Have you checked out the DIY Projects section at all: https://www.diydoctor.org.uk/projects.htm? There is a project relating to "Blowing Light Bulbs" that may be of some use to you: https://www.diydoctor.org.uk/projects/bulbs.htm
Hope this help!
Regards
by ericmark » Fri Aug 29, 2008 11:40 am
You say light but not what type a pendent bulb is unlikely to need anything more that changing bulb where a florescent normally has built in fuse but if as you describe more likely to need new fitting.
Eric
It is currently Sat Nov 23, 2024 3:15 am
