No Hotwater from bath tap BUT fine in all other taps
chrisgodridge
by chrisgodridge » Tue Sep 02, 2008 11:35 am
I have a problem with no hotwater coming from the bath tap, just a drip. Hot water works fine in both the bathroom sink and the kitchen, both further from my boiler that the bath.
The bath fawceetes are separate but the tap is a mixer with shower swith. As you'd expect there is no hot water when using the shower either. I have recently removed 2 radiators in my house but this problem only surfaced over 2 weeks after doing this.
The hot water system is combi boiler - there is NO tank.
Does anyone have any idea what this might be?
plumbbob
by plumbbob » Tue Sep 02, 2008 6:01 pm
The logical conclusion is you have a faulty tap. You can rule out plumbing, as the that has worked fine in the past. Airlocks can also be discounted as you have a pressurised system. That only leaves one possibility.
Dismantle the tap and examine.
chrisgodridge
by chrisgodridge » Tue Sep 02, 2008 8:12 pm
Thanks for the advice... I'm on it now. I'll let you know.
chrisgodridge
by chrisgodridge » Tue Sep 02, 2008 10:15 pm
Thanks plumbbob - the spindle wasn't retracting fully. Poblem solved, appreciate your help.
It is currently Fri Jan 10, 2025 8:53 pm
