Fitting flooring up against a stone wall
simon55
by simon55 » Mon Sep 15, 2008 2:11 pm
I live in A 100 year old cottage where one of our intrenal walls in the livingroom is a stone wall. I want to fit laminate flooring in this room but I will be unable to get the laminate to butt up along the stone wall as it is uneven. The other 3 walls will be fine as I am going to pull the skirting off and replace with new. should i cut a profile on the laminate of the stone face or should I use a filler to seal the gaps??
Any easy fix for this problem or easy way to cut an uneven profile on the laminate??
Regards
Simon
It is currently Sun Jul 07, 2024 2:24 pm
