Moving ceiling rose
pipk62
Moving ceiling rose
by pipk62 » Sat Sep 27, 2008 6:58 pm
Hi.
Just want a clarification as to whether I can carry out this simple task, and advice if forthcoming.
I have a ceiling light that I am taking down, but I wish to remove the rose and move it elsewhere in the room.
The route of the new cable would go through a wooden beam
I have been given some advice, but I am unsure whether it is correct...
I have been told that I am able to put a junction box where the ceiling rose is (this is possible without it being seen as there will be a fitted shelving system that runs under where the rose is) this will allow me to simply run a spur to wherever I want, and should there be any requirement in the future to check the connection it would be accesible without difficulty.
As for the wooden beam, I should use a 10/12 auger bit exactly in the centre of the beam, which is at its point of least stress.
This is all to double check what I have been told, as I'm unsure of what the new regulations say.
by ericmark » Sun Sep 28, 2008 1:50 pm
What you account does seem OK until you get to what new regulations say. I will try to give you a condensed version.
1) To dissipate heat cables need to be clipped or otherwise held to a cool surface this is mainly due to the possibility that latter insulation is added.
2) The cable must either surface or buried more than 50mm or of a type where if a nail of similar is knocked through it a short to earth will be created or protected by a RCD.
Without seeing any job one can make errors and what I would say is use common sense. I believe there is a 1/3 rule on drilling beams and they should only be drilled in the centre 1/3 of it’s span.
There are junction boxes that don’t use screws but have a spring clip arrangement which are permitted to be used where there is no access.
Eric
It is currently Wed Feb 05, 2025 11:02 pm
