Boiler Back Flushing into the water tank
Dalus
by Dalus » Sun Sep 28, 2008 11:31 pm
I've searched the forum for this problem and could find nothing of a similar nature.
I have a Vokera 12-48 rse boiler and when i turn water on to it so it has pressure (1-1.5 bar), it causes water to flow into the water tank through one of the water feed pipes at the bottom. This is causing the overflow pipe to run constantly, and is causing a small leak on the side of the tank itself where the overflow exits the tank.
Is there any common problems that would cause this to happen?
I am unfamiliar with plumbing, so thanks for any advice.
drm090163
Re: Boiler Back Flushing into the water tank
by drm090163 » Tue Sep 30, 2008 7:22 pm
[quote="Dalus"]Hi,
I am unfamiliar with plumbing, so thanks for any advice.[/quote]
Hi can you explain slightly better, what tank are you talking about? is it say red or orange?
drm090163
Hi sorry but need more info as dont know exact boiler
by drm090163 » Tue Sep 30, 2008 7:29 pm
Is it a regular boiler? A combi? these are the first questions ok.
Dave
by htg engineer » Wed Oct 01, 2008 8:30 pm
This is a system boiler, designed to be used on sealed systems only.
If the manufacturers instructions have been followed, and it is a sealed system, if when re-pressurising the system - the water flows from the over flow, then it may be a split/corroded cylinder coil.
htg
It is currently Sat Jan 11, 2025 2:13 am
