Cavity wall insulation without drill holes everywhere?
starkraving
by starkraving » Wed Oct 01, 2008 12:44 pm
I've had cavity wall insulation in my previous house, and it was done by drilling lots of holes on the exterior walls and pumping insulation in. That was okay because, after the holes were filled I painted the house.
However, my new house has bright white dashing on it, and I'm sure it would look a mess if holes were drilled all over it. I'm sure even filling the holes with the same type of dashing would look bad. Is there any kind of cavity wall insulation that I can use without drilling loads of holes? A few holes would be acceptable.
Perry525
by Perry525 » Sat Oct 04, 2008 8:10 pm
Not as far as I know!
You can drill the holes on the inside!
the specialist
by the specialist » Wed Jan 07, 2009 7:53 pm
Polystyrene beads (unbonded) use far less holes. There was a system called isodan but I dont know if it is still around. It is possible to patch bright white dashing to perfection. I know because I have done it. You just need to find someone who is careful and pays attention to detail.
Aidan
It is currently Sun Dec 22, 2024 1:44 pm
