radiator not heating up.
chrisroberts
by chrisroberts » Sat Oct 04, 2008 11:23 pm
radiator in kitchen not heating up. just had 2 new valves fitted. trv on the flow and a trv on the return. should i have a normal valve on the return side instead of a trv. are the trv's fitted with a none return valve in them. thanks.
plumbbob
by plumbbob » Mon Oct 06, 2008 12:29 am
TRV's are not fitted with non return valves. Only one trv should be fitted to a radiator. The other end should have a lock shield (normal valve with a tamper proof cover) set to regulate the correct flow of water through the radiator.
The usual causes for a cold radiator is blocked pipe caused by an airlock or sludge.
screech
by screech » Tue Oct 07, 2008 10:22 pm
2 trvs, never heard of that being done before, how the hell would anyone balance that rad :?
It is currently Fri Nov 22, 2024 12:15 am
