cavity wall insulation and the use of cavity trays.
Ask questions and find answers on a range of subjects relating to self build projects
6 posts   •   Page 1 of 1
teamleader
by teamleader » Mon Oct 06, 2008 6:29 pm
how can i ge round the problem of having to fit a cavity tray, when the whole house has cavity wall insulation! surley its just gonna fall down and fill the tray anyway? am i right in thinking 99% of wall insulation stops this any way, more so if its simular to "instafibre".
would treating the wall with a clear waterproofer help?
cavity tray
by welsh brickie » Tue Oct 07, 2008 12:42 pm
use catnic boot lintols over all openings the design eliminates the use of dpc cavity trays and are fully insulated
teamleader
by teamleader » Wed Oct 08, 2008 8:59 am
cant replace the lentol as its in the original opening of the building and the wall insulation has been in about ten years. (and cost me a loy of money, so dont want to lose or disturb it).
cavity tray
by welsh brickie » Thu Oct 09, 2008 4:22 pm
there is no way to install cavity trays unless you demolish the external brickwork above each opening
the insulation has some waterproof resistance but you could spray a clear silicone solution to the walls,it all helps
the specialist
by the specialist » Sun Jan 11, 2009 8:01 pm
Please could you explain why and where you are thinking of installing a cavity tray. Was in the cwi business for 20 years so hopefully i can help.
TheDoctor5
by TheDoctor5 » Wed Jan 28, 2009 10:34 am
It is currently Mon Jan 06, 2025 8:49 pm
