replacing a busted door frame after someone broke in?
bshifflett
by bshifflett » Wed May 09, 2007 11:18 pm
How do you replace a busted door frame after someone forceably pushed the door open and broke the frame that has the lock latches?
thedoctor2
by thedoctor2 » Thu May 10, 2007 8:26 am
Depending on the damage there if its not to bad then cut out the damaged area and splice in new timber, the splice should be at an angle this will increse the security, glue and screw, shape to match the existing replace the hard ware .
Hope this has been of help to you
bshifflett
by bshifflett » Thu May 10, 2007 5:02 pm
:D I was hoping it was something simple - and had envisioned replacing the whole frame. this really helped. Thanks so much!
It is currently Sat Dec 28, 2024 9:27 pm
