Unlevel Shower Tray
misterdun
Unlevel Shower Tray
by misterdun » Tue Oct 14, 2008 11:23 am
I am installing a non-easy plumb screwfix shower tray onto newly laid 18mm chipboard. There is about a 15mm drop between back to front and was wondering what the best way to level it off would be. I was thinking of packing the lower end but also putting down a layer of cement/sand to strengthen it or is it best to lay a wet mix, if so what would be the best mix to use and do i need to add pva?
TheDoctor4
by TheDoctor4 » Tue Oct 14, 2008 4:51 pm
Have you had a look at the DIY Projects area at all: https://www.diydoctor.org.uk/projects.htm There are several projects relating to shower installation and also one forfitting a shower tray that may be usefull: https://www.diydoctor.org.uk/projects/showertray.htm
Regards
misterdun
by misterdun » Wed Oct 15, 2008 8:00 am
Thanks for the reponse garnico1307, i had laready checked the projects page out and have searched extensively on the web. I can see that i will probably have to put a cement/sand mix but can't find any advice on a mix, should it be a dry mix or fairly runny etc.
bobbych
by bobbych » Wed Oct 15, 2008 9:34 am
a sand and cement base is the normal way to level it. Dont just pack the low end. the try need to be supported over most of its base or it will flex and break the seal to the screen
chris_on_tour2002
by chris_on_tour2002 » Wed Oct 15, 2008 10:13 am
use a wet mix of sand and cement with pva/admix in it as an anti-crumbling agent to help prevent it breaking up.
seal the plywood with pva as well, a 3:1 mix, apply the sand and cement when the pva is still tacky.
It is currently Sun Nov 24, 2024 10:20 pm
