sealed saracen upvc windows are jammed how to fix
lemin
by lemin » Tue Oct 14, 2008 6:53 pm
Apparently easy to fix but cant seem to work it out, I have now three saracen uvpc double glazed windows where the bottom locking bolt has come adrift from the handle mech therefore jamming the window shut, how is this problem fixed please .
Damsel in distress
Natasha
syscure
Re: sealed saracen upvc windows are jammed how to fix
by syscure » Fri Mar 27, 2009 10:38 am
[quote="lemin"]Apparently easy to fix but cant seem to work it out, I have now three saracen uvpc double glazed windows where the bottom locking bolt has come adrift from the handle mech therefore jamming the window shut, how is this problem fixed please .
Damsel in distress
Natasha[/quote]
I took inner glazing bar off (go careful) next to latch, then drilled small hole (about 4mm) through the newly exposed frame parallel with the glass through to the dropped bar. then jimmy it up with a screwdriver.
Fix or remove the offending part then refit the glazing bar and no one will ever know.
It worked for me.
It is currently Mon Dec 23, 2024 4:48 am
