Can anyone help with adding an extra spur
Sleepy
by Sleepy » Sun Oct 19, 2008 5:08 pm
Hi, I need an extra double socket in a bedroom, but ive run 2.5mm T&E from the new socket as a spur to an existing socket. Now arriving (backwards, I know!) to the existing socket I note there are 3 cables, I guess this means it already has a spur. So,the question is,would the best thing be to connect the existing socket to a FCU, 13 amp (meaning threre would still be 3 cables in it with the extra one now going to the FCU.) And then run both spurs from the FCU. (It wont be practical to run from the FCU to one spur, then from that spur to another spur.) Or maybe put in another single socket, by connecting one set of ring cable wires from the existing socket to a new single socket directly next to it if they will reach, and leaving the ring and existing spur in the existing socket, then running the new spur from the new single socket. But if I do this, do I need to link the existing socket and the new single socket together, otherwise ill be breaking continuity of the ring wont i?
by sparx » Sun Oct 19, 2008 8:44 pm
Hi, errr yes I think!!!
OK you mention some options each of which seem ok,
To do as 1st way would mean identifying and moving original spur to position of new FCU etc.
2nd way to add a socket to ring then have one spur from each, also more wiring.
If your cabling is under floor to existing socket can't you get to one of the 2 ring cables and insert a Joint box to spur your new socket?
At this point the 'purists' (or sad gits) will no doubt start on about access to screw term. joints.......In my 45 years in the trade I can't remember a problem with JB's if connected well & as you will have had to make a 'trap' to do the wiring a note of where stuck by consumer unit should IMHO do the trick,
usual 'take care to isolate/disclaimer'
regards SPARX
Sleepy
by Sleepy » Fri Oct 24, 2008 7:48 pm
Thanks for that, sorted!
It is currently Sat Jan 18, 2025 7:27 pm
