filling in the gaps around windows
6 posts   •   Page 1 of 1
chappers_sc
by chappers_sc » Sat Nov 01, 2008 10:06 pm
I have just bought a terrace house and the windows have all been replaced recently. The windows have not been finished off and there are gaps varying from 5mm to 25mm all around the wooden windows, this is also around the front door frame. I was wondering how to fill this in. Do i use bits of brick and cement in and around, or can i use expanding foam and mastick to finish?! Some other way maybe?
Steve
Perry525
by Perry525 » Sun Nov 02, 2008 6:00 pm
I assume that they have fitted the windows and door correctly?
If they have then the most secure way to finish them is to carefully pack the holes with mortar, this will joint the frames to the wall and make it more difficault for them to be knocked down.
If you don't care to use this method, then using a low expanding foam will do the job better from a heat loss point of view. Then plaster up to the frames.
mraich
Expanding foam
by mraich » Sun Jan 04, 2009 7:52 pm
[quote="Perry525"]I assume that they have fitted the windows and door correctly?
If you don't care to use this method, then using a low expanding foam will do the job better from a heat loss point of view. Then plaster up to the frames.[/quote]
Where can I find some of that LOW expanding foam and how much does it cost for a can? Arer there different brands? Thanks
Perry525
by Perry525 » Mon Jan 05, 2009 5:33 pm
Just enter low expansion foam on Google.
Its about £4 a can.
You can get it from Toolstation and I think Screwfix.
Perry
the specialist
by the specialist » Fri Jan 09, 2009 7:04 pm
b&q, wickes any builders merchant etc etc
TheDoctor5
by TheDoctor5 » Thu Jan 22, 2009 9:31 am
It is currently Thu Nov 21, 2024 11:27 pm
