zone 1 fan
L&A
zone 1 fan
by L&A » Thu Nov 20, 2008 10:06 pm
Hi. I am experiencing excessive condensation on the toilet cistern, it is a small bathroom and I am going to line the cistern; but I am wondering if there is an extractor fan that I can set in the ceiling in zone 1 - I believe that is the right name. Anyway it's above the bath! thanks.
mdpmspitfire
extract fan
by mdpmspitfire » Wed Nov 26, 2008 10:43 pm
hi, yes there is. its suitable for shower cubicals. you could even connect it via a humidistat.
also if your bathroom is excessively warm and you are able to reduce temp, particually when you are not using it, you may dramatically reduce the problem. mains fed cisterns or well lagged storage tanks are the worst culprits
mark
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 9:38 am
It is currently Mon Nov 25, 2024 1:28 pm
