Electrics for shower
SC81
by SC81 » Wed Nov 26, 2008 8:43 pm
Hi. Currently have a 8.0kw shower running from a 30amp fuse. Which has been working fin for the last 10 years. I understand that a 30amp fuse is only supposed to run a 7.5 kw shower???
I am changing the shower as it is old. I was wondering what is the best shower around (power - wise) in that rating bracket or make of shower. Or will it not make any difference?? For example will a mira 8.0kw shower be more powerful than a triton with it being a better make.
Many thanks
nitro23456
by nitro23456 » Thu Nov 27, 2008 3:17 pm
In my opinion Mira are the best but the extra money you spend on a Mira probably evens it out benfit-wise with a cheaper Triton if that makes sense?!
Essentially you get a better shower but spend more money, with a triton you get a shower that works and saves you money.
From a 30amp supply fuse you shouldnt have an electric shower at all!
It is currently Sat Jan 11, 2025 10:50 am
