I am reasonably new here so any help or advice is very much appreciated!
I am currently fitting a kitchen and we have a stand alone gas oven/hob which is to be replaced with a gas hob and electric oven. My question is in regard to the electric oven!!
I have read various things about wiring for an oven (I don't plan on wiring it my self, just running the wiring in). From what I understand, the oven will need its own fuse with wiring running to a double pole cooker switch! Is this right??
If the above is correct, what kind of wire do I need to run (basically what would I ask for in the shop)? The oven will be about 4-5 metres from the fusebox!!
Any help would be GREAT..........I am running the wiring myself to try and save ssome cash as I can see it being a bloody fiddley job as the wiring will have to go through 2 roof areas and down a channel in the wall!
Thanks to anyone that helps!!
S
