Combi boiler but not enough water pressure
SHL
by SHL » Wed Dec 03, 2008 2:51 pm
I am doing up a house that I bought last year. Which involved moving the bathroom upstairs.
After having a perfectly working water tank etc replaced by a combi boiler, because everyone I spoke with highly recommended a combi boiler. I have been left with hardly any water pressure at all.
It has since been revealed that we share the main water supply with our next door neighbour - with them receiving the water first and then us. Thames Water will charge a fortune to set up our own mains.
I just wanted to know if there is anything that can now be done to give sufficient power to the nice big shower head I have in my walk-in shower?
Had I of known that it could end up like this, I would have never gone for a combi boiler.
Thames Water did say that I might be able to put a pump on somewhere just before the boiler as the water pressure is so low. Is this an option?
Otherwise, what is the answer to achieving a powerful shower now? Would the only option be to put a water tank back in? How much would I be looking at to do this?
Dont know if its worth mentioning but at the moment I am unable to get cold water out of the shower, on the lowest temperature it is still rather warm.
Also the water pressure is not as strong coming out of the bath or shower as it is out of the kitchen taps. Although the sink upstairs does seem just about sufficient.
Any advice would be really really appreciated. As I have lost all confidence in asking my current plumber anything.
bobplum
by bobplum » Wed Dec 03, 2008 7:50 pm
hi
under normal condtions you are not allowed a pump to be installed on mains supply but can see your point/problem
if you did put a pump on my concern would be the the volume of water may not be there as next door have taken the bulk of it and the pump would make little difference what little water their is would only come out faster but with no great pressure and the more they used the less you would have for the combi
you may be able to fool the combi into thinking its geting mains feed by installing a water tank in the house and pumping it to the combi?
i dont know what the other guys think of this
any suggestions anyone?
It is currently Tue Jan 28, 2025 11:47 pm
