Fixing Toilet Bowls To The Floor
Billy Whiteside
by Billy Whiteside » Mon Dec 08, 2008 11:56 am
My plumber wants to stick a toilet bowl to a tiled floor rather than fixing it with srews. Is this sensible ? :shock: [color=brown][/color][size=18][/size]
matthewm1965
by matthewm1965 » Mon Dec 08, 2008 12:34 pm
I have stuck down two now in our house, using silicone sealant.
Neither have moved yet after a year of daily use.
Matt
chris_on_tour2002
by chris_on_tour2002 » Mon Dec 08, 2008 7:58 pm
better to use screws although it is quite common for plumbers these days to use silicone alone to secure toilet pans. personally i use both. it should hold fine.
plus side it does save making holes in the tiles.
plumbbob
by plumbbob » Mon Dec 08, 2008 11:24 pm
I always stick the toilet down with silicone whenever an underfloor heating mat has been installed. I know the mat shouldn't actually be under the toilet, but am too scared to even think about drilling anywhere near it.
Once stuck, as matthewm1965 says, they don't move.
Clyde
by Clyde » Tue Dec 23, 2008 2:49 pm
I actually had this dilemma a few weeks a go. In the end, after thinking long and hard I went with screwing to the floor (tiled) with the screws/bolts that came with it, and nice chrome screw caps. If in the future I need to get to water inlet/soil pipe (everythng is enclosed/back to wall toilet) I just undo the side screws and slide the toilet pan out nice and easy!
I've been in a position in the past were pans have been stuck down with sealant and its a nightmare prising it from the sealent, then you've got all the sealant to scrape away if you then re-seal.
It is currently Fri Nov 22, 2024 12:30 pm
