penetrating dampthrough solid brick wall
pistonbroke
by pistonbroke » Mon Dec 08, 2008 8:24 pm
I have a serious problem with penetrating damp. The house is of solid brick construction (Yellow Stocks with Lime Mortar courses)built in about the 1870's.The damp is coming in at a height of about 2-3 metres on an external corner,spreading about 1 metre on either side of the corner.The walls are Sandtexed. I've checked the brickwork and pointing,but can find no obvious faults.
Is there a waterproofing product that can be applied on top of Sandtex,or do i need to strip back the affected area to bare brick ?
Alternatively.Is there a waterproofing product that can be applied to the interior walls ?
Barry
by stoneyboy » Thu Dec 11, 2008 12:26 pm
pistonbroke,
Are the external walls sandtexed or are they brick?
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 9:50 am
It is currently Sat Dec 21, 2024 3:55 pm
