Fitting a stone shower tray
7 posts   •   Page 1 of 1
jimcars
by jimcars » Fri Dec 12, 2008 4:03 pm
Hi can someone please advise. I am about to fit a stone shower tray in but need to raise to allow for water to drain away. Would 18mm plywood WBP hardwood be right for this job. Is this product suitable for the job as water will be around this area.
Regards Jim.
by stoneyboy » Fri Dec 12, 2008 9:57 pm
jimcars,
we need more information - is the existing floor concrete, wood, chipboard or something else?
plumbbob
by plumbbob » Sat Dec 13, 2008 1:37 pm
This topic may help.
https://www.diydoctor.org.uk/forums/view ... hp?p=41646
Use 18mm exterior grade plywood.
jimcars
by jimcars » Sat Dec 13, 2008 5:53 pm
[quote="stoneyboy"]jimcars,
end[/quote]
Hi the floor is concrete.
Regards Jim.
jimcars
Re Fitting a shower tray
by jimcars » Sun Dec 14, 2008 4:11 pm
I hope to fit two shower trays, one on a concrete floor and one on a wooden floor hope this helps.
Regards Jim.
by stoneyboy » Mon Dec 15, 2008 10:31 am
jimcars,
For the one on concrete form a concrete base with the wast pipe buried in it - allow a large hole around the waste for final positioning. For the one on timber, if you cannot get the waste below floor level, form a timber frame, fit WPB ply top with tray on that.
jimcars
by jimcars » Mon Dec 15, 2008 11:47 pm
end[/quote]
Thanks for the advise.
Regards Jim.
It is currently Sat Dec 21, 2024 1:54 pm
