Gas boiler installation in attic
Malcolmh
by Malcolmh » Sun Dec 28, 2008 2:47 pm
Is it possible to install a gas boiler with a vertical flue in an attic supported on a stud frame wall, as we haven't got any solid walls?
Steve the gas
by Steve the gas » Mon Dec 29, 2008 8:39 am
Hi Malcolm,
I've never been asked this before - but I suppose so as long as it meets all Regs.
I.E. Wall strong enough?
Floor boarded at least up to boiler?
Permanent light?
Handrails?
Proper loft ladder?
Hth
gasmick
by gasmick » Tue Dec 30, 2008 10:07 pm
Hi there are loads of problems with having a boiler fitted in a roofspace as Steve says with also the addition as well of a gas isolation valve is to be fitted bellow the ceiling so the boiler can be isolated in case of a leak ,
as far as the studding for the support is concerned it will have to be non combustable surface i suppose you could cover the surface with alluminium closure plates,
And its also possible that an additional frost stat may have to be fitted to the return pipework to protect the pipes from freezing,, some boilers have an internal one fitted, but that only protects the boiler internals
Another problem is if you need to adjust the temp of the heating and water, plus you will need an external clock system fitted ,
I have allways talked people out of it to be honest,
i now only do servicing and breakdowns and i always ask where the boiler is located if its in the roof i will not attend to it as its a pain testing things and keep going up and down the ladder carrying kit up and down
hope this helps Mick
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 12:29 pm
It is currently Thu Feb 06, 2025 6:45 am
