Connecting dishwasher hot water feed
jetblack
by jetblack » Sun Dec 28, 2008 4:03 pm
I currently have a washing machine which is connected with both hot and cold water.
I am about to fit a dishwasher too and this requires only a hot feed. How do i split my hot water feed so that both dish washer and washing machine get a feed?
I was assuming i would fit a tee piece from the current hot water feed to the dishwasher but when i went to the hardware store i could not find a splitter that would do the job..
Can anyone point me in the direction of what i might need?
by htg engineer » Sun Dec 28, 2008 7:02 pm
Are you sure it a hot only feed you need ? it would normally be hot and cold or just cold.
It's a eay enough job for a competent DIYer, you either tee into the copper pipe with:
http://www.screwfix.com/prods/12004/Plu ... Tee-15mm-x
or a tee piece and standard val;ve.
or use :
http://www.screwfix.com/prods/15272/Plu ... -Piece-BSP
screws onto existing valve then the two appliance hoses screw on too.
htg
jetblack
by jetblack » Mon Dec 29, 2008 12:18 pm
Its only got 1 inlet hose and its got a red end on it so i assume thats a hot feed...
Thanks for the info on the tee piece. That should do it.
:D
wynyard
by wynyard » Tue Dec 30, 2008 10:19 pm
[quote="jetblack"]Its only got 1 inlet hose and its got a red end on it so i assume thats a hot feed...
:D[/quote]
It is not usual to have a hot feed to a dish washer for two reasons: cold water is required for the condensing cycle of the wash, to help dry the plates etc and hot water may be fed from a tank in the loft, where all sorts of things get into the water.
While the temperature of a wash cycle will kill most of the bugs, it is not good practice to use a hot feed.
It is currently Sun Nov 24, 2024 6:41 am
