ceiling pull cord switch, can you help?
glasmale26
by glasmale26 » Fri Jan 02, 2009 7:24 pm
I have just replaced a ceiling pull cord swith with a new one and replaced the three bulbs in the fitting but for some reason the light still does not work? The pull cord swith has two terminals, one says 'COM' and one says 'L1' which I presume to be live,
The cable has a red wire, a black one and a earth which is connected.
I tried both combinations, ie the red one into L1 and COM and then swopped them round,
Is there anything else I am missing??
I cant have been sold 3 dodgy bulbs could I???
securespark
by securespark » Sun Jan 04, 2009 1:04 am
Have you replaced the light fitting as well as the switch?
by ericmark » Sun Jan 04, 2009 11:45 am
I can't see a fault.
Although Supply Line to Com and Switch Line to L1 is normal it does not normally matter if swapped.
Are you sure not part of two way switching
why can't you test bulbs in something else?
Eric
It is currently Tue Dec 24, 2024 6:25 pm
