no water upstairs
dean7231
no water upstairs
by dean7231 » Sun Jan 04, 2009 1:44 am
could somebody help with this please,i have no running water upstairs in taps or toilet syetem. i have water downstairs cold only,it sounds like to me that the cold feed isnt filling the tank up. could i do something to sort this out or does it sound like a big job?
SweetBriar
Re: no water upstairs
by SweetBriar » Sun Jan 04, 2009 8:19 pm
[quote="dean7231"]could somebody help with this please,i have no running water upstairs in taps or toilet syetem. i have water downstairs cold only,it sounds like to me that the cold feed isnt filling the tank up. could i do something to sort this out or does it sound like a big job?
Go into your loft and see if the ballvalve on your cold water tank (the larger one of two) has got stuck.
tina-marie
by tina-marie » Mon Jan 05, 2009 1:17 pm
we have had the same problem as you and to fix it you must partly open all the top hot taps to the highest floor to let out the air when the water starts to run in the bath slightly open the sink tap at the same time to let out the air.
Keep the top hot taps slightly turned on until the air disperses.
Good Luck
Tina-marie
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 1:20 pm
It is currently Sat Nov 23, 2024 6:58 am
