by ericmark »
Fri Jan 16, 2009 11:25 am
You can get mast head amplifiers which will allow multi outputs from one aerial which if the signal is poor is best way. But where you have a good signal a Y connector may well do the job. TV aerial cables are "matched" and when you split you need to add some resistors to keep it matched which are included in a Y connector not simple connect two wires together.
All depends how good your signal is.
