Shower Problem
scoobie
Shower Problem
by scoobie » Tue Jan 06, 2009 6:55 pm
It's recently started to play-up. Sometimes when it's turned on the flow seems to be greater and there is no-hot water. Or, someone can shower, and the next person to use it just after will just get cold water. It's combi boiler fed, and a manual control temp.
The taps in the same bathroom are recieving hot water.
I was just going to fit a new shower unit/mixer tap to include a thermostatic valve (upgrade it), but somehow I don't think it will solve the problem.
The property is a barn conversion, converted 2000, split level - about 3 steps - so the boiler has to pump about 30' and up 4'.
Thanks in advance.
by stoneyboy » Thu Jan 08, 2009 5:26 pm
scoobie,
Do what you planned and see if a new valve will sort the problem.
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 1:25 pm
It is currently Tue Nov 26, 2024 9:15 pm
