immersion heater not enough hot water
scutmore
by scutmore » Thu Jan 08, 2009 11:54 am
[/b]Hi, there is not enough hot water from my immersion heater. if i leave the immersion on all night and have a bath or shower in the morning it runs cold after about 3 or 4 minutes. the size of the cylinder is 4ft deep by 1.5ft wide. i refitted a new element about ayear ago. the size of the element is approx 2 ft. do you think that the elemet is not sufficient? on the side of the tank it says that the maximum element size should be 200mm less?
plumbbob
by plumbbob » Thu Jan 08, 2009 5:45 pm
You don't say what type of cylinder it is, but a standard immersion element is 700mm (27") long. The shorter type that you seem to have are only used to give a small "emergency" supply of hot water.
Obviously you have checked the temperature setting to ensure the water is at 65 degrees?
mattpark
by mattpark » Fri Jan 16, 2009 11:04 pm
You have not said whether you have gas heated hot water as well as the immersion, if so what type of system is it ?
If you do have gas I would strongly recommend using it and only use your immersion for 'breakdowns' - as its far cheaper than putting the immersion on overnight.
If you fitted a new element, was it like for like ? and - did it provide sufficient hot water for your system before you changed it ?
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 1:43 pm
It is currently Sat Nov 23, 2024 2:57 pm
