Sealing tiled splashback
yorksvilla
by yorksvilla » Sun Jan 11, 2009 12:26 pm
Anyone recommend a good way of sealing new tiles and grout on splashback above a range cooker so it becomes easily cleanable and repels grease?
Did it myself
by Did it myself » Tue Jan 13, 2009 10:47 am
I sealed our tiles with a crackle-glaze. It now repels water etc and is easily cleaned. You may not need a crackle glaze (depends on your tiles), but i'm sure there will be other types of glaze to use.
TheDoctor5
by TheDoctor5 » Wed Jan 28, 2009 10:59 am
It is currently Fri Nov 22, 2024 9:39 pm
