Torbeck Valve Problem
sylvester
by sylvester » Wed May 16, 2007 9:24 pm
Hello
Hope someone can help?
I have just fitted a Torbeck cistern valve ( for a bottom Inlet) When the water has finished filling up and the float rises to the top it makes a loud thud. Somebody told me to turn the water pressure down at my stop cock but that hasn't help either. Can somebody help? :roll:
howy1
by howy1 » Thu May 17, 2007 2:46 am
Torbeck valves come with a flow restrictor that goes inside at the bottom of the valve , did you put this in !
howy1
by howy1 » Thu May 17, 2007 2:54 am
Hi did you put the flow restrictor in that comes with the valve !!
sylvester
by sylvester » Thu May 17, 2007 8:29 pm
Hello
Thanks for replying (Torbeck cistern valve) yes I did attach the comb filter to the flow restrictor and then I put it back together again. But mine came with two flow restrictor and one comb filter I presumed the other was a spare.
howy1
by howy1 » Thu May 17, 2007 10:56 pm
The pressure regulators are for low and high pressure water supply`s you may have the wrong one in , they tell you which is which via the instructions and it has lp or hp on respectivly .
It is currently Mon Dec 23, 2024 5:11 am
