Mould spots on bathroom sealant?
ruud1boy
by ruud1boy » Sat Jan 24, 2009 5:23 am
We had a new bathroom fitted recently (Spring '08) and we're starting to see evidence of mould on the bath sealant already.
They're only small spots at present, but it's bally annoying!
We're fairly good at wiping down after using the bath/shower, but obviously it's not possible to avoid the sealant getting wet. I've tried cleaning it with a mould remover, but it appears to be immune to that.
Can anyone offer any tips on how to remove the mould & keep the sealant clean?
Inform Timber and Damp
by Inform Timber and Damp » Sun Jan 25, 2009 1:18 pm
You will need to cut off sealant and reseal using an anti fungicidal sealant.It is quite a common problem, try to regularly dry off sealant to avoid te start of the mould and wipe with bleach
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 10:21 am
It is currently Sat Sep 14, 2024 10:51 pm
