Hissing noise from pipes
malpractice
by malpractice » Sun Jan 25, 2009 11:12 am
There is a hissing noise similar to the noise when a toilet is re-filling coming from the pipes. The toilets are ok and the noise persists even when everything is turned off and the stop cock is turned off. Any ideas.
Stelf
by Stelf » Sun Jan 25, 2009 7:45 pm
There is a strong chance you have a leak in the underground water main before it enters your property. Your water company will almost certainly investigate for you if you ask but you may have to hire your own plumber to fix the problem.
Best wishes
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 2:27 pm
It is currently Mon Nov 25, 2024 9:53 pm
