Speedfit for immersion heater
spider147
by spider147 » Mon Jan 26, 2009 6:27 pm
Hi all, due to changing my house layout, I need to move my immersion heater, hot water pipes from boiler and header tank in the loft. Are speed-fit pipes and connections suitable for all these jobs?
Many thanks
by stoneyboy » Tue Jan 27, 2009 10:42 pm
spider147,
Many plumbers use plastic pipe and fittings even for heating applications. I still do not believe that a single rubber O ring (which all these type of fittings depend upon) has the same life as a soldered or compression fitting.
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 2:30 pm
It is currently Mon Nov 25, 2024 11:27 am
