Two Quotes For Work – Which is the rip off merchant?
DIYuseless1
by DIYuseless1 » Mon Feb 09, 2009 6:14 pm
Hi and thanks in advance for your help.
A chap knocked our door and to cut a long story short he wanted to replace our facias, guttering etc with PVCU. After some negotiating as it is something we’ve been thinking about since moving in we agreed a healthy sounding sub £1000 figure to cover over the original wood. He also said he would replace any rotten wood he found. Now other than the price I want to give this guy the work because it sounded like it’s very much tough times out there currently, not to mention the price seemed just about affordable.
Then had a call from another company offering the same service so took up their offer of a quote, £8,500 down to £5,500, down to £3,250 to fully remove and replace all the wood. We also had a horror story about just covering the wood up so my questions are these:
If the wood is ok is it ever OK to cover it with PVCU?
Or should we not even consider it and replace the lot?
And under the new HIPS, is it effected if it’s covered up?
by stoneyboy » Tue Feb 10, 2009 10:10 pm
DIYuseless1,
If you are lucky you will get what you pay for all upvc claddings are not equal.
At the bottom of the range there is the stuff which is completely hollow and at the top there is the foam skinned planking which is thick enough to replace the wood facias.
There is not a problem with covering sound facias unless the underfelt has failed and water is getting into the top of the facias. When this work is being done you do need to consider cross ventilation of the roof.
I don't think the HIPs survey will be affected by this work.
If you are not going to be in your home very long go for the cheap option it will look tidy for a short time - let someone else have the longer term problems.
rosebery
by rosebery » Tue Feb 10, 2009 10:43 pm
"£1,000"
How big is the house?
"£8,500 down to £5,500, down to £3,250"
Run away!
TheDoctor4
Local help at hand!
by TheDoctor4 » Fri Jul 09, 2010 10:17 pm
For up to 5 FREE quotes from trusted, vetted and insured tradesmen in your area visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Sat Jan 04, 2025 2:12 am
