Gap around the glass?
CarlP
by CarlP » Sat Feb 14, 2009 3:13 pm
Should I have a small gap around the glass edge in a double glazed unit?
I have just removed the beading from a window and all but one side meet the frame - this window has actually misted hence the reason for trying to replace it.
Also any Idea of where I could get fresh beading from?
by stoneyboy » Sun Feb 15, 2009 3:32 pm
CarlP,
There should be a gap all round the DGU and setting blocks should be fitted at strategic positions aroung the frame.
A local glazing firm should be able to supply you replacement beading but take a sample so you get the same section.
CarlP
Success
by CarlP » Sun Mar 08, 2009 9:13 am
Thanks for the help
what a result
window 15 (glass supplier) blocks 6 (ebay) no beading required
total 21 to replace one window
It is currently Mon Dec 23, 2024 4:10 am
