Replace Primatic with indirect cylinder
6 posts   •   Page 1 of 1
stigdee
by stigdee » Sat Feb 14, 2009 10:13 pm
Hi guys ..My ancient Primatic hot water cylinder sprung a leak and I replaced it with an indirect cylinder...trouble is the central heating doesnt work anymore....do I need to add another F&E tank to the system ( the old system just had 1 feed tank) if I need to add another feed tank where do I connect it to the new indirect cylinder ? please also be aware i'm a total novice at plumbing :lol:
rosebery
by rosebery » Sun Feb 15, 2009 11:34 pm
Yes you do need a separate F&E tank and that MUST be piped properly and not connected to the cylinder. With all due respect I think you need a plumber.
stigdee
by stigdee » Mon Feb 16, 2009 10:33 am
Thanks for the reply rosebery I thought as much....im guessing it needs to be connected to the pipework leading to the coil ?
gasmick
by gasmick » Tue Feb 17, 2009 11:44 pm
you have just created a time bomb so do not turn on the boiler as there is now no expansion to the system the expansion tank should go in the roof with a cold feed and an expansion pipe over the tank
anyway you should not be fitting the repacement cyld yourself as it comes under the building regs notification scheme so only a competent person IE corgi engineer is classed as such so he can self certificate
i think you will see on the side of the new cyld there is such a notice that should be filled in
Ime afraid its all down to regulations these days gone are the days when d i y could do anything
rosebery
by rosebery » Wed Feb 18, 2009 7:52 am
"anyway you should not be fitting the repacement cyld yourself as it comes under the building regs notification scheme so only a competent person IE corgi engineer is classed as such so he can self certificate"
Thats not so. You only have to be registrered for unvented with a G3 ticket. For vented if you employ an Insitutue Of Plumbing member you do not need to involve Building Control. He doesn't need to be CORGI (Gas Safe from 1 April).
You CAN do it yourself but you DO need to involve Building Control.
stigdee
by stigdee » Wed Feb 18, 2009 9:50 am
Thanks again for the info guys....."Time Bomb"....Phew!!!....I can live without heat until I can get a plumber involved.
It is currently Mon Nov 25, 2024 7:58 pm
