Metal gate?
claire27
Metal gate?
by claire27 » Tue Feb 17, 2009 3:37 pm
I need to install a gate between the house and the garage to keep the dog in. it would need be be nearly 4 feet wide and atleast 6 fett high.
can anyone recommend a resonbly priced supplier of such item?
:?: I know you can get then specially made but are a bit pricy, the house is only rented.
by stoneyboy » Wed Feb 18, 2009 7:09 pm
claire27,
Suggest you use a wooden gate - it will be cheaper, lighter and easier to install.
claire27
by claire27 » Fri Feb 20, 2009 1:54 pm
Wood is no good i have a staffy and she like to chew wood!
If a wooden gate was used to keep her in she would chew it till she could get out!!
There has to be a supplier of metal gates who do wider than average gates
by stoneyboy » Sat Feb 21, 2009 4:05 pm
claire27,
In which case buy a wood gate and clad the dog-exposed side with a sheet of aluminium, or go round your local metal working firms and see if they have any rejected or oops made-wrong-size gates.
It is currently Tue Nov 26, 2024 6:55 pm
