Plasterboarding on to solid outside wall
7 posts   •   Page 1 of 1
Hammy
by Hammy » Sun Feb 22, 2009 10:17 pm
Hi, hope someone can help. I own a house 100+ yrs old and need to repair the plaster on an outside wall that is in poor condition. I will attempt most things however I'm not so sure about plastering a whole wall. I was thinking of drylining this wall. Should I dot and dab or batten. The wall is quite thick however there is no cavity in the wall and the house can suffer from condensation at times.
Many Thanks
kbrownie
by kbrownie » Tue Feb 24, 2009 9:47 pm
hi hammy,
Answered much the same type of question on another post.
Apply a liquid d.p.m. to stone/brick wall,
then fix stud work and insulate in between stud work,
vapour check barrier this can be fixed seperate or be part of a plasterboard system.
Then fix plasterboard (if not using the pre-vapour checked board)
KB
rosebery
by rosebery » Tue Feb 24, 2009 10:49 pm
Dot and dab. You'll be forever trying to get it nice and level with battens.
What are you planning to cover the plasterboard with? The obvious answer is to skim it and decorate afterwards. Don't decorate staright over plasterboard! But for skimming it you'll need a plasterer!
Why not get one or two in to give you a quote?
rosebery
by rosebery » Wed Feb 25, 2009 9:35 pm
KBs post has much merit as he has looked beyond the immediate question in the lead post. Careful not to reduce the room size too much.
armytouch
outside wall?
by armytouch » Mon Mar 16, 2009 10:49 am
Hi Hammy hope you well,i was reading your post and confused me a little,you dont mean to plasterboard a outside wall?
I assume you mean an internal wall?
rosebery
by rosebery » Mon Mar 16, 2009 10:55 pm
I had assumed he meant the inside of an outside wall.
by stoneyboy » Tue Mar 17, 2009 10:03 pm
Hammy,
With solid walls it is important that the internal surface can breath to get rid of moisture/condensation.
If you cover the wall with plasterboard the evaporation cannot take place and any condensation (which will get to the cold outer wall through the egdges of the plasterboard) will appear as water coming out across the floor.
Stick with a proper job - replaster the wall.
It is currently Sun Nov 24, 2024 8:33 am
