Fitting Re-claimed Timber Floor
steve Parker
by steve Parker » Sun Mar 01, 2009 5:04 pm
I am renovating an 18th century cottage. It has concrete floors sealed with a black paint on mastic. I want to fit reclaimed timber floor and intend to put down a plastic sheet as a damp membrane, then 1" battens with thermal insulation between. The flooring would be nailed to the battens. How can I fix the battens down and maintain a damp proof seal please (or any other proposals you may have to achieve the same insulated floor)?
eastwood flooring
Re: Fitting Re-claimed Timber Floor
by eastwood flooring » Tue Mar 31, 2009 7:27 pm
[quote="steve Parker"]I am renovating an 18th century cottage. It has concrete floors sealed with a black paint on mastic. I want to fit reclaimed timber floor and intend to put down a plastic sheet as a damp membrane, then 1" battens with thermal insulation between. The flooring would be nailed to the battens. How can I fix the battens down and maintain a damp proof seal please (or any other proposals you may have to achieve the same insulated floor)?[/quote]
Hi steve, why not seal the concrete floor with a dpm liquid screed. when dry glue the battens to it and then lay floor on battens as planned. have you taken a moisture reading? should be less than 18% max allowance.
It is currently Sat Nov 23, 2024 12:48 am
