I have just replaced a light fitting in my hallway. Having completed the fitting and tested the light it works, however ALL the other lights in my flat are now dead. There is power to all wall sockets so tv etc all work, just the lights that are out. I have tried new bulbs in each fitting but none work so I have eliminated blown bulbs.
The wires were red and two blacks, I am 100% on this having checked with a torch before installing. My concern is that I had put the live wire to the neutral first then switched the wires and got the light working. I believe i had the fuse box off at all times although I wonder if its that which has blown. But surely then my hall light would not work either?
Help, I am literally in the dark!
Alex
