Draining/refilling combi boiler system
8 posts   •   Page 1 of 1
Tott
by Tott » Wed Mar 25, 2009 7:13 am
I need to replace a sticking TRV (tried the usual tapping the pin/moving up & down/tapping valve/WD-40 to no avail) so need a few pointers in doing it/draining system correctly, do I just...
Turn off at stop cock, turn off boiler, drain system (I've a drain cock on rad).
Fit new TRV.
Refill system, bleed rads (any particular order - there's 2 upstairs in loft conversion, 6 downstairs), top-up system, repeat 'til right.
And should I be adding inhibitor at some point and how and where do I do this?
TIA
Steve the gas
by Steve the gas » Thu Mar 26, 2009 7:09 am
Hi Tott,
Yes, mainly as you say but,
Bleed rads downstairs first,
Add inhibitor via a rad bung/plug- remove plug,screw in a 15mm compression elbow minus its nut and olive, then pour it in.
Do all above before finishing bleeding,using the dosage stated on the bottle.
Hth
Tott
by Tott » Thu Mar 26, 2009 12:51 pm
...cheers Steve, much appreciated.
Doneroaming
Draining a combi etc.
by Doneroaming » Fri Apr 03, 2009 8:43 am
[quote="Steve the gas"]Hi Tott,
Hth[/quote]
Hi Steve
Would the same apply to a combi boiler system in a Static
Caravan and could you put antifreeze in the same way ? PLEASE
Steve the gas
by Steve the gas » Sat Apr 04, 2009 5:03 am
I would !!
Doneroaming
Antifree ina Static Van
by Doneroaming » Tue Apr 21, 2009 10:38 am
[quote="Steve the gas"]I would !![/quote]
Cheers Steve for the Info and could I ask which Antifreeze You would use
in a Static caravan
PLEASE
Steve the gas
by Steve the gas » Wed Apr 22, 2009 5:29 am
I have never used such stuff.
But I guess its sold at a caravan supplies outlet so I would do as stated on the bottle.
Doneroaming
by Doneroaming » Wed Apr 29, 2009 10:21 am
[quote="Steve the gas"]I have never used such stuff.
But I guess its sold at a caravan supplies outlet so I would do as stated on the bottle.[/quote]
Cheers Steve Thank You for Replying !
It is currently Mon Nov 25, 2024 3:58 am
