elson double fed indirect hot water tank
Markxs
by Markxs » Tue May 22, 2007 9:29 pm
Very simple question how do I identify which is the mains input pipe?
by htg engineer » Thu May 24, 2007 5:29 pm
the mains cold water pipe in the very top pipe, will be 15mm copper. Connected to the ball valves. Should have a stop tap fitted near the tank (not the red wheel head one)
Markxs
by Markxs » Fri May 25, 2007 10:06 am
Cheers I can now cut the pipe with confidence,,,,,,,,,,,,,,Now if only they would answer my questions on the electrical side :D
It is currently Mon Dec 23, 2024 6:03 am
