Replacing a fixing to a Plasterboard Wall
Colin1
by Colin1 » Sat Apr 04, 2009 6:25 pm
I've got a problem with a fixing to a plasterboard wall.
Basically, one of the brackets that supported a curtain rail has come loose and the fixing hole has become enlarged. The hole is now too big for an 8mm rawlplug, but not deep enough for a 10mm rawlplug, nor deep enough for a metal anchor.
I'd prefer to avoid having to drill into the plaster behind th plasterboard. Does anyone have have any suggestions or know of shorter rawlplugs that still fit a 10mm hole?
kbrownie
by kbrownie » Mon Apr 06, 2009 9:25 pm
have you thought of filling the hole in, then re drilling it.
KB
rosebery
Re: Replacing a fixing to a Plasterboard Wall
by rosebery » Tue Apr 07, 2009 12:34 am
"Basically, one of the brackets that supported a curtain rail has come loose and the fixing hole has become enlarged."
Im guessing because it used a standard wall plug which do not work with plasterboard.
"I'd prefer to avoid having to drill into the plaster behind th plasterboard."
Why? - that would seem to be the only sensible aproach.
Colin1
by Colin1 » Tue Apr 07, 2009 12:23 pm
[quote="rosebery"]
Cheers[/quote]
Lack of DIY ability to be fair. Which probably answers the question regarding filling and re-drilling, I just don't have a clue whether that would work, as in would the filled hole hold the bracket?
Looks like I might need to drill into the plaster
It is currently Sat Nov 23, 2024 8:48 am
